beanonymous89
Jul 29, 2018Aspirant
Netgear Nighthawk M1 - Telstra - fireware Update
I have a few Nighthawk M1's that are used as a 4G failover at clients sites and I have had a lot of trouble with these units going to sleep when I need them ready at a moments notice.
Now I hav...
- Jul 31, 2018
Hi beanonymous89,
Please follow option 2 in the following article: https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
Let me know if you have any problems.
- ArodiD
JSchnee21
Jul 31, 2018Virtuoso
Are these AT&T units? The firmware comes direct from them over the air. Log into the Admin interface to via a web browser to check for updates. Similarly, you can disable the Ethernet timeout via the web interface. There have been multiple firmwares in 2018 (for AT&T). The newest (from June) seems pretty good. My unit (Gen1) is much more stable now.
- beanonymous89Jul 31, 2018Aspirant
No it is via the carrier Telstra in Australia.
Its weird.
Some devices find it right away and others done, so if I can get the offline copy of the firmware would be supper helpful.
I have to update over 30 x M1 devices and this number will only grow.
- ArodiDJul 31, 2018NETGEAR Expert
Hi beanonymous89,
- ArodiD
