beanonymous89
Jul 29, 2018Aspirant
Netgear Nighthawk M1 - Telstra - fireware Update
I have a few Nighthawk M1's that are used as a 4G failover at clients sites and I have had a lot of trouble with these units going to sleep when I need them ready at a moments notice.
Now I hav...
- Jul 31, 2018
Hi beanonymous89,
Please follow option 2 in the following article: https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
Let me know if you have any problems.
- ArodiD
JSchnee21
Jul 31, 2018Virtuoso
Are these AT&T units? The firmware comes direct from them over the air. Log into the Admin interface to via a web browser to check for updates. Similarly, you can disable the Ethernet timeout via the web interface. There have been multiple firmwares in 2018 (for AT&T). The newest (from June) seems pretty good. My unit (Gen1) is much more stable now.
beanonymous89
Jul 31, 2018Aspirant
No it is via the carrier Telstra in Australia.
Its weird.
Some devices find it right away and others done, so if I can get the offline copy of the firmware would be supper helpful.
I have to update over 30 x M1 devices and this number will only grow.
- ArodiDJul 31, 2018NETGEAR Expert
Hi beanonymous89,
- ArodiD
