MFK2020's avatar
MFK2020
Netgear nighthawk M1 , Web admin login redirected and blocked
Greeting all ,    I changed the Gate way default on the rooter to 192.168.1.2 to avoid the conflict with another modem.   The modem is on IP passthrough   Now when I'm trying to get access to t...
  • MFK2020's avatar
    MFK2020
    Nov 15, 2022
    I finally reset the M1 , I could not set the default gate way as 192.168.0.1 , it  only accept 192.168.1.4 , so I set it as 192.168.1.4
    Now it's working well and I can have access on it and no conflict with the other modem
    Thanks John  and others for the support
