MFK2020
Nov 13, 2022Aspirant
Netgear nighthawk M1 , Web admin login redirected and blocked
Greeting all , I changed the Gate way default on the rooter to 192.168.1.2 to avoid the conflict with another modem. The modem is on IP passthrough Now when I'm trying to get access to t...
- Nov 14, 2022
I finally reset the M1 , I could not set the default gate way as 192.168.0.1 , it only accept 192.168.1.4 , so I set it as 192.168.1.4
Now it's working well and I can have access on it and no conflict with the other modem
Thanks John and others for the support
JohnPeng
Nov 14, 2022NETGEAR Expert
Using 192.168.1.2 should be able to access the WebUI.
Please connect the device using USB cable to your computer and check IPconfig whether IP gateway is set correctly to 192.168.1.2? The USB port IP address should be 192.168.1.4.
Thanks
MFK2020
Nov 14, 2022Aspirant
Thanks John for your reply ,
I did already my default gateway is 192.168.1.2 both USB or LAN,
I tried all IP .4,.5,.6 just in case without success
Also with different computers and systems, the web page still redirected and blocked.
I don't know if there is another way to read the M1 setting
- JohnPengNov 14, 2022NETGEAR Expert
USB default IP must be 192.168.1.4, which is set on FW and can't be changed. If you change the gateway IP to 192.168.10.1, USB IP will be 192.168.10.4.
Make sure when you change the default gateway, the LAN IP range is also updated accordingly.
Thanks
John
- MFK2020Nov 14, 2022Aspirant
I like this path
I did change my default gateway when I had the chance to reach the M1 setting I change it to 192.168.1.2 because it was conflicting with my other modem
So which IP I will use now ?
If the gateway IP is conflicting with your other network, you should change the gateway IP to the following:
192.168.x.1 - x can be any number, except 1. Then M1 will be on a different subnet. You still can use the same subnet mask as 255.255.255.0
Thanks
John
