MFK2020
Nov 14, 2022Aspirant
Netgear nighthawk M1 , Web admin login redirected and blocked
 Greeting all ,      I changed the Gate way default on the rooter to 192.168.1.2 to avoid the conflict with another modem.     The modem is on IP passthrough     Now when I'm trying to get access to t...
- Nov 15, 2022
I finally reset the M1 , I could not set the default gate way as 192.168.0.1 , it only accept 192.168.1.4 , so I set it as 192.168.1.4
Now it's working well and I can have access on it and no conflict with the other modem
Thanks John and others for the support
MFK2020
Nov 15, 2022Aspirant
That was my mistake at the first place, I should have set the default gate way on 192.168.0.1 instead of 192.168.1.2
For the conflict between the modems, now it's ok , I use a personal computer which is not connected to the network.
I don't now why the URL is redirected.
MFK2020
