Amershan
Dec 19, 2022Aspirant
NetGear nighthawk m1 boot loop
My Nighthawk MR1100 router constantly restarts. It initiates power on and the "NETGEAR" logo shows up on screen, the amber light shows up and then after 3-5 seconds it shuts off again and then powers...
Am_marmaid
Feb 14, 2023Aspirant
Hello. Are you solved problem? Im from Poland honory want to help me… i have the same problem
Amershan
Feb 17, 2023Aspirant
Hi, no sadly i did not solve the problem nor can i move past of the loop. Seems like i have an expensive paperweight
