shmuoi's avatar
shmuoi
Netgear Nighthawk M1 cant port forward at all.
Cant port forward on the mobile router would I have to get a router to plug into it or is there a way to fix it on the nighthawk?
  • > Can[']t port forward on the mobile router [...]
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Port
    Forwarding".
       When I did that for a "MR1100 - Nighthawk M1 Mobile Router", I found
    a section which describes how to do it.  Is that User Manual wrong, or
    is your model/firmware different, or what?
       "Can[']t" is not a useful problem description.  It does not
    say what you did.  It does not say what happened when you did it.  As
    usual, showing actual actions (commands) with their actual results
    (error messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       Note: "cant" is a word, different from "can't".
    • shmuoi's avatar
      shmuoi
      My bad also didnt know there was a difference. I have read the user guide on how to port forward but my issue is that I put in the ports but it just doesnt work and my nat is always strict 3.
      • antinode's avatar
        antinode
        Guru
        > [...] I put in the ports but it just doesnt work [...]
           Regarding "doesn[']t work", see "Can[']t [...]", above.
           What are you doing as a test?  What, exactly, "doesn[']t work"?
           What, exactly did you "put in" where?  What are your actual
        port-forwarding rules?  Copy+paste is your friend.
        > [...] showing actual actions [...] actual results [...]
           Which part of "actual" was unclear?
           What is the WAN/Internet address of your router?  Is it a public
        address?  What is the LAN IP address of your server?
           Why are you doing this?  What is the actual problem which you are
        trying to solve?
