Ricdsk
Jul 03, 2021Aspirant
Netgear Nighthawk M1 MR1100-1TLAUS Stuck in Boot Loop. Won't turn on. Please help.
My Netgear Nighthawk M1 router until a couple of hours ago was working completely fine. I took the SIM out, put on another and restarted it, and now it's stuck in some sort of boot loop. When on Ba...
Blanca_O
Jul 21, 2021NETGEAR Employee Retired
Hi Ricdsk
Welcome to NETGEAR Community!
Was there any changes prior the issue?
Was there a firmware update?
Have you tried factory resetting the device?
Please remove the SIM card and hold down the reset button until you see a change in the LED.
Blanca
Community Team
Ricdsk
Jul 22, 2021Aspirant
Hi Blanca_O , thanks for tackling my question. No issues at all, unless, not showing 'data used' stats constitutes?
Yes, I've tried factory resetting multiple times.
I've tried a replacement battery.
But all to no avail. Nothing seems to affect our hey it out of the boot loop. Perhaps I'm missing something.
