Huoloc
May 17, 2019Follower
Netgear Nighthawk M1 MR1100 downgrade
Hi, my Netgear MR1100 device has overheated after updating to version NTG9X50C_12.06.02.00, the battery consumes very quickly even if only 1 user connects, What to do to downgrade the firmware, thanks.
1 Reply
I would try doing a factory reset first. If you remove the back panel, there's a reset bottom on the bottom.You can also do it through the settings. Here's the walk through from the att version.
