wilshing
Oct 21, 2019Tutor
Netgear Nighthawk m1 MR1100 Firmware 12.06.07 cannot operate without battery
After upgraded to firmware 12.06.07, my netgear m1 cannot operate without battery inserted. It keeps rebooting. Before the upgrade, it works normally just using ac adapter (with no battery in...
- Oct 21, 2019
This is a known issue with the current release (12.06.07.00). The main fix in the latest release was to address the reset being experienced by some users. There should be a new FW release soon to correct the no battery problem.
Here are the release notes for the latest FW:
https://kb.netgear.com/000061333/MR1100-Firmware-Version-NTG9x50C-12-06-07-00-00
LTEGuy
Oct 21, 2019Star
mli
Oct 22, 2019Tutor
Same problem here.
Hope the fix has helped more people than it has hurt. :smileyhappy:
