wilshing
Oct 21, 2019Tutor
Netgear Nighthawk m1 MR1100 Firmware 12.06.07 cannot operate without battery
After upgraded to firmware 12.06.07, my netgear m1 cannot operate without battery inserted. It keeps rebooting. Before the upgrade, it works normally just using ac adapter (with no battery in...
- Oct 21, 2019
This is a known issue with the current release (12.06.07.00). The main fix in the latest release was to address the reset being experienced by some users. There should be a new FW release soon to correct the no battery problem.
Here are the release notes for the latest FW:
https://kb.netgear.com/000061333/MR1100-Firmware-Version-NTG9x50C-12-06-07-00-00
LTEGuy
Oct 21, 2019Star
neverknowwhat
Oct 22, 2019Aspirant
Wouldn't it be more helpful to describe how we can make a firmware downgrade?
- mliOct 22, 2019Tutor
In hindsight, the upgrade notification should warn if a known bug is introduced to avoid the risk of upgrading firmware and then downgrading firmware.
If the above is too technically difficult to implement, a boilerplate warning to read the release notes would help those consumers feeling lazy at the time and tempted to trust in the competence of vendors. :smileyhappy:
- LTEGuyOct 22, 2019Star
A new release will be released soon to resolve the no battery reset. For now the recomended work around is to run with the battery installed.
