Sebastiii
Oct 26, 2019Star
Netgear Nighthawk m1 MR1100 Firmware 12.06.08 available
Hello, A new firmware update available in web interface 12.06.08. Quick test looks goods, maybe it will fix reboot issues. No changlog available so far it seems
MikaelDui
Oct 28, 2019Guide
I'm experiencing some issues with native IPv4 and IPv6 dual stack.
Only either IPv4 works or only IPv6 works.
When only IPv4 works I can't even see any IPv6 address under Settings -> Status -> Network.
When only IPv6 works I can see an IPv4 address.
I've not gotten both working at all with this update and I've reset the device multiple times as well as restarted it and using settings backups.
My phone using the same LTE carrier has no issues doing both IPv4 and IPv6 at the same time.
MikaelDui
Oct 28, 2019Guide
To solve the IPv4/IPv6 issue I just waited a while and then did another reset. Everything solved and IPv4 and IPv6 works flawlessly again.
- SebastiiiNov 02, 2019StarHi,
This is the changelog :
https://kb.netgear.com/000061374/MR1100-Firmware-Version-12-06-08-00
Also, I have done another firmware update and in final, it was the same version number.
And this time, it gives me back ethernet standby option. :)
