Sebastiii
Oct 26, 2019Star
Netgear Nighthawk m1 MR1100 Firmware 12.06.08 available
Hello, A new firmware update available in web interface 12.06.08. Quick test looks goods, maybe it will fix reboot issues. No changlog available so far it seems
thom127
Nov 04, 2019Aspirant
Is your App still Working? For me the mobile app isn’t working so I can’t change my data limits. Is that also possible via the web interface? I liked using the app but it tells me now it’s not possible to use this router with the app...
- thom127Nov 04, 2019AspirantMy fault, was because of a proxy in between. All working :)
- ViewpointNov 14, 2019AspirantHi, since downloading this firmware, I’ve had continuous internet dropping every few minutes. It only comes back on after rebooting. Weird thing though, it will stay on all day so f you’re streaming something. As soon as there’s not constant flow of data, 3 -5 minutes it’s out and have to reboot. Anyone here have any tips?
- SebastiiiNov 14, 2019StarHi, it looks like ethernet standby issue nut set to disable. This option is back on the latest firmware on my side. Twice update from same number build. Maybe look at this option 👍
