Sebastiii
Oct 26, 2019Star
Netgear Nighthawk m1 MR1100 Firmware 12.06.08 available
Hello, A new firmware update available in web interface 12.06.08. Quick test looks goods, maybe it will fix reboot issues. No changlog available so far it seems
thom127
Nov 04, 2019Aspirant
My fault, was because of a proxy in between. All working :)
Viewpoint
Nov 14, 2019Aspirant
Hi, since downloading this firmware, I’ve had continuous internet dropping every few minutes. It only comes back on after rebooting. Weird thing though, it will stay on all day so f you’re streaming something. As soon as there’s not constant flow of data, 3 -5 minutes it’s out and have to reboot. Anyone here have any tips?
- SebastiiiNov 14, 2019StarHi, it looks like ethernet standby issue nut set to disable. This option is back on the latest firmware on my side. Twice update from same number build. Maybe look at this option 👍
- ViewpointNov 14, 2019AspirantI have checked this settings to ensure it was on “never”. It did not change anything. I do feel it is a bug in the standby settings. I have to stream a radio station in the background to keep the internet going.
I've looked at the setting and I have set it to "ETHERNET STANDBY" to "Disabled"
But like I have a device connected to internet 24/24 even if not much data over this device, it can act like keepalive thingy.
I remember doing a fresh reset setting after the upgrade too to clean in case of leftover strange settings.
So maybe this is a bug but can be triggered here at least.
- MikaelDuiNov 14, 2019Guide
I've had the same issue, internet dropping all the time, often just 5 minutes after restarting the router.
But, I've not had the issue for over 1 week now - I've transfered over 100 GB without issues. I plugged it into a Quick Charge charger and did a factory reset. However, my ISP was having some trouble with the data at the same time so I'm not sure if it was the ISP or the Nighthawk.
Good point, I have also change original power supply by quick charge one :)
- MikaelDuiNov 17, 2019GuideMine has now been returned (RMA) because of the constant internet drops after this update.
While looking at how to return it the internet connection dropped 3 times!
I'll wait for a replacement unit since there are no other mobile routers near as powerful as this one - I don't want to downgrade to Cat 4/6/9.
