Sebastiii
Oct 26, 2019Star
Netgear Nighthawk m1 MR1100 Firmware 12.06.08 available
Hello, A new firmware update available in web interface 12.06.08. Quick test looks goods, maybe it will fix reboot issues. No changlog available so far it seems
MikaelDui
Nov 17, 2019Guide
Mine has now been returned (RMA) because of the constant internet drops after this update.
While looking at how to return it the internet connection dropped 3 times!
I'll wait for a replacement unit since there are no other mobile routers near as powerful as this one - I don't want to downgrade to Cat 4/6/9.
Viewpoint
Nov 17, 2019Aspirant
I don't know why, but for some reason, seeing that the two other posts had something to do with charging, I removed the battery and powered directly from the charging cable. I haven't had a drop since. I also rechecked that the wifi standby was disabled. I'm not sure which one did it but I'm positive that I've had the wifi standby disabled prior. But after so many reboots and factory resets it may have slipped by. Either way check these two, no more problems.
- dv83dNov 17, 2019Aspirant
AT&T 6420B band 14 model works with this latest firmware?
- SebastiiiNov 18, 2019StarI have removed the battery too. MR1 is connected to quick charger and also on backup ups.
- dv83dNov 18, 2019Aspirant
I’m thinking of removing battery plug into USB power bank & plug power bank into outlet.
