Sebastiii
Oct 26, 2019Star
Netgear Nighthawk m1 MR1100 Firmware 12.06.08 available
Hello, A new firmware update available in web interface 12.06.08. Quick test looks goods, maybe it will fix reboot issues. No changlog available so far it seems
Viewpoint
Nov 17, 2019Aspirant
I don't know why, but for some reason, seeing that the two other posts had something to do with charging, I removed the battery and powered directly from the charging cable. I haven't had a drop since. I also rechecked that the wifi standby was disabled. I'm not sure which one did it but I'm positive that I've had the wifi standby disabled prior. But after so many reboots and factory resets it may have slipped by. Either way check these two, no more problems.
