john_nc
Aug 16, 2019Aspirant
Netgear Nighthawk M1 MR1100 Firware Update 10.20.05.02
Factory Reset...Battery is Full >90% Unit plugged in. Try Firmware Update and I am stuck on NTG9x50C_10.20.05.02 10.20.05.02 Says Downloading 0% And hangs there. I attached a screenshot. ...
Big7Boss
Aug 20, 2019Tutor
Same here....
- Blanca_OAug 22, 2019NETGEAR Employee Retired
Hi john_nc
Checking on the screenshot, you have an AT&T unit. Are you using an AT&T SIM?
May we please know the model number of your NETGEAR MR1100?
Blanca
Community Team- Big7BossAug 22, 2019TutorHere.
This model SKU 6112B MR1100-1A1NAS.
Thanks - john_ncAug 22, 2019Aspirant
yes, att sim card
- john_ncAug 23, 2019Aspirant
Ok, just had an idea.
I purchased another M1 after returning the first one.
I had saved the settings from my first unit and was able to upload that file .cfg
Can someone with an ATT network router and updated with current firmware send me/upload a generic (admin/attadmin) .cfg file. I think if I upload this it might have the updated firmware...worth a shot!
current firmware is dated from 2017
