ronaldvr2132
Jul 06, 2018Apprentice
Netgear nighthawk m1 mr1100 max size micro sd
What is the maximum size that the Micro SD Card installed in a MR1100 can be? The manual says 128 GB, but I have read on more places that 256 GB works as well. Is that correct and will every brand wo...
ronaldvr2132
Jul 12, 2018Apprentice
Does someone has a 265GB SDXC card up and in the MR1100?
- Blanca_OJul 15, 2018NETGEAR Employee Retired
Hi ronaldvr2132,
Welcome to NETGEAR Community!
Please provide the link where it shows that is supports 256 GB so I can verify it with the team. It says on the users manual that it support up to 128 GB.
Blanca
Community Team
- ronaldvr2132Jul 16, 2018ApprenticeSee underneath, step 5 of the tutoria as referred to underneathl): https://www.att.com/devicehowto/tutorial.html#!/interactive/id/interactive_1500014796?make=Netgear&model=NetgearMR1100
- TeeJay74Jul 17, 2018Virtuoso
256 GB card can be used.
