aawada
Jul 02, 2018Aspirant
Netgear nighthawk m1 mr1100 random rebooting
Hello, My nighthawk m1 router is randomly rebooting by itself, mainly when there is heavy usage. I tried to put the battery on with charging plug same issue remained. Reset the router and remove 5g...
JSchnee21
Jul 06, 2018Virtuoso
Hi aawada,
Welcome! Yes, many of us have had this issue over the past 6 months. In general, you can usually address this issue by doing the following:
1) throw out the included AC power adapter and replace it with a reputable QC2 or QC3 charger (Anker). I use this one:
2) Disable dual band Wifi. Use only one band. Preferrably 5.8Ghz assuming all of your devices support it. Else 2.4 Ghz. But keep in mind 2.4 GHz will severly limit your throughput (assuming your cellular connection is fast enough). You'll also need to increase the range to "Long" as the Wifi range on the MR1100 is pretty weak (compared to my ZTE hotspots, for example). Many of us have disabled the on hotospot wifi all together and connected a proper Wifi AP via Ethernet for fixed installs. Something like this one works well:
3) Be sure your MR1100 firmware is fully up to date, the original firmware from ~Feb 2018 was very bad. The newer firmwares 12.0.6.x (forget exact number) have been better. When mobile in the car, my device used to frequently panic when switching to/from certain specific cell towers. Not sure why. This seems better now.
4) Keep the device cool. It's sensitive to warm weather, especially with regard to battery charging.
Given a strong cell tower with fiber back haul, I've seen up to ~120Mbit on AT&T. Usually though its only ~15 to 60 Mbit in the areas I frequent (PA/NJ).
Good luck,
Jonathan
