seanebue
Jul 20, 2019Star
Netgear Nighthawk M1 MR1100 Telstra in Philippines
Purchased Date: July 2019 Model: Nighthawk M1 MR1100 Telco: Telstra Firmware Version: 10.?.?.? I forgot! Firmware Updated: 12.06.02 ISP: LTE SIM (Globe Philippines) The Nighthawk M1 I bought...
seanebue
Jul 20, 2019Star
Yes, I had the Globe APN set correctly, I set it up manually.
zaido
Aug 24, 2019Tutor
Would you be able to share the APN settings? Or was it automatically setup upon inserting the Globe sim?
I'm also planning to travel in the PH and purchase an M1 online, I saw that M1 is compatible only with SmartBro so I'm choosing between the two carriers.
- seanebueAug 24, 2019StarWhen you insert your Globe sim it does not automatically add apn. APN is simply internet.globe.com.ph.
To add APN:
Just click add and named it Globe and type the APN.- zaidoSep 04, 2019TutorThanks! We're you able to use SmartBro as well? I'm using it now but could only get 2mbps download speed. My APN is just "internet". Anyone knows if there's a better or updated APN for SmartBro prepaid?
- seanebueSep 04, 2019Star
I was not able to test smartbro eversince I acquired my m1...
Note: as per my own experience, the m1 is effective more on travel and outdoors. If you will use indoors it might give you just more than what the ordinary pocket wifi, that means if ordinary pocket wifi gives you 1mbps or less then m1 might give you 2 or 3mbps speed.
