seanebue
Jul 20, 2019Star
Netgear Nighthawk M1 MR1100 Telstra in Philippines
Purchased Date: July 2019 Model: Nighthawk M1 MR1100 Telco: Telstra Firmware Version: 10.?.?.? I forgot! Firmware Updated: 12.06.02 ISP: LTE SIM (Globe Philippines) The Nighthawk M1 I bought...
Salamat18
Sep 04, 2019Initiate
Hello,
can I asked where did you buy your Nighthawk M1? Was is over Lazada and than coming from China?
Does it still work and are you still happy with it here in the PH ?
Best regards
Frank
- seanebueSep 04, 2019StarThe purchased was done thru Lazada.. I just forgot whether from China, The M1 I received was from Telstra Telecom which we all know that Telstra is from Australia.
Yes, I am very happy with my Netgear Nighthawk M1 performance until now. There is no pocketwifi here in Philippines can achieve the same speed. I tested all pocket wifi here in Phillippines and it is uncomparable with M1- Salamat18Sep 06, 2019Initiate
Thanks for the info! Will get me one too.
