Ultradragon
Oct 01, 2018Follower
Netgear Nighthawk M1 MR1100
Good day all, I really enjoyed using my Netgear nighthawk M1 MR1100 but my problem is I'm using it all the time and its battery consumes too fast because we are 4 persons. I'm still using this ...
- Oct 15, 2018
Suggest you to remove the battery and having power adaptor, supporting Quick Charge, connected to your M1's Type-C port if you are running 24/7.
If you are taking M1 as home router, then having another wireless router, such as Nighthawk R7800, set as your main router, M1 just provide LTE connection without WiFi running would eliminate the concern on its heat dissipation and provide better coverage.
W1lliam
Oct 15, 2018Virtuoso
