Abbud7
May 01, 2019Aspirant
Netgear Nighthawk M1 MR1100
Hello, Recently I bought a Nighthawk M1 MR1100 and it was working fine until I updated the firmware. I want to know if there is a way to downgrade my firmware. I think it’s because of the update that...
Abbud7
This is the link of my product:
https://www.netgear.com/support/product/MR1100RDMES.aspx#Firmware%20Version%2012.06.03.00
But i cant see any old firmware versions>
additude
May 02, 2019Virtuoso
It appears that is the only version available. There are no previous versions.
The firmware version ending in .00 may be an indicator that there are no previous versions, but naming conventions are of their own accord and only mean something in relationship to each other.
In the past I have found on the "Download" page for my Netgear equipment that there is a seperate link to previous versions of firmware. That link is not available here so there must not be any previous versions.
- schumakuMay 02, 2019Guru - Experienced User
Are you operating the MR1100 Ooredoo version on the intended provider and it's non-roamed network?
Reason asking is that there are several reports that it appears the MR1100 (or some variants of it) are no longer allowed to run the better/faster channels in other countries and/or other providers, leading to subpar performance.
- Abbud7May 02, 2019AspirantYes I’m operating with the intended provider. But It sometimes works and it’s fast and sometimes it’s slow and doesn’t even if I’m the only one using it.
