noodlehonk
May 05, 2022Aspirant
Netgear Nighthawk M1 not connecting no matter what
Ive been dealing with this for about two months, I just bought my service again thinking it was my ISP but it almost immediately ran out. I heard from people that the firmware is glitched and ive hea...
May 05, 2022Guru - Experienced User
What ran out?
Your data?
How much data do you get a month? (keep in mind, most unlimited plans throttle speeds after a certain data limit)
- noodlehonkMay 05, 2022Aspirant
I should state ive had this router for a few months and its just starting now so I really doubt its the phone plan. I have a gold straight talk unlimited plan with tmobile. Recently it has been using up the hotspot data, not the unlimited data so when I hit only 15gb it basically shuts down instantly. Nothing loads at all and its unusable.
- plemansMay 05, 2022Guru - Experienced User
it could by how your isp is coding it. If its using the "hotspot data" and its connected to a hotspot, they've probably figured that out.
For a while you could use a phone sim card in a hotspot and use "unlimited" data. Sadly, like I said, network providers figured out users were doing that and could compare the sim to IME data.
Could be that's what yours has done. Did you check with them?
