Gomez1824's avatar
Gomez1824
Follower
Dec 06, 2020
Netgear Nighthawk M1 speed eratic
When checking the speed of my router on AT&T unlimited plan I get speeds just above 70 mbps. Then I check a minute later and get .16 mbps. I’m not using an external antenna. The speed seems to vary constantly causing annoying buffering.
Would an external antenna help?
No RepliesBe the first to reply
