seanebue's avatar
Jan 13, 2020
Netgear Nighthawk M1 Telstra Firmware to EU Firmware
Hello to everyone!
Just wanna ask if possibly I can change my stock firmware from Telstra to EU? Currently, the firmware installed to my Nighthawk M1 is this MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04.secc and I wanna use this MR1100-100EUS_23113509_NTG9x50C_12.06.03.00_00_Generic_05.01.secc.spk
By the way, if in case this is possible what would be the differences between the 2 firmware and which is more better from the 2 firmware.
Thank you in advance and I hope you could share your thought on this.
  • Hi, me to i'm very interesting but, i think it will never be possiblle cause testra use OTA upgade process with is homemade personalized OS.
    The difference beetween the 2 version is than EU will be update more, very more frequently.
    But if some one get the process to flash AUS build to EU built OS, i will want to test. thanks everyone
    • seanebue's avatar
      seanebue
      Star
      that is the reason why I wanted to flash my M1 from Telstra to EUS, frequent updates. When your M1's firmware are always updated, that means there are lots of improvements and possibilities.
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    It is impossible to load EUS release on Telstra device since the HWs are different and they are not compitable.
    Thanks
