lenl
Sep 20, 2019Initiate
Netgear Nighthawk M1 vulnerability
When will Netgear release a solution / fix for the Netgear Nighthawk M1 vulnerability as mentioned in the link below ? VulDB 140070 · CVE-2019-14527 Netgear Nighthawk M1 prior 12.06.03 Web Interf...
- Oct 02, 2019
Hi, All,
This has been brought up already to engineers. No security vulnerability has been found on our test.
Please check reference link:
https://kb.netgear.com/000061155/Security-Advisory-for-Firmware-Encryption-on-MR1100-PSV-2019-0055
Blanca
Community Team
Oxygene
Sep 20, 2019Apprentice
Upgrading to version 12.06.03 eliminates this vulnerability.
Blanca_O
Oct 02, 2019NETGEAR Employee Retired
Hi, All,
Blanca
Community Team
- sena71Oct 16, 2019Tutor
lmaooo are you sure about that? then explain to me how im able to force a telnet session with the internal linux/busybox OS? smh you guys couldn't even be bothered to change the root password from the default "oelinux123"
So tell me, are you absolutlely 100% sure there is no exploit?
