Lance77
Aug 12, 2021Aspirant
Netgear Nighthawk M1 wont connected to Vodaphone UK sim
Hi I bought a Nighthawk M1 recently. I added a vodaphone UK sim with data into the device. Logged into the dashboard. Clicked set up APN and vodaphone was selected in the automatic choice in the cell...
Lance77
Aug 16, 2021Aspirant
It's a phone sim with minutes, texts and a big data package. So it sounds like ive chosen the worst possible network with Vodaphone. Whats my solution; buy a data only package or just go with another network, if so what's the easiest network to set up with?
Im on payg so I would only lose £15 if I choose another network.
AyeAyeAye
Aug 16, 2021Apprentice
https://forum.vodafone.co.uk/t5/Archive/APN-Settings/td-p/1179473
Try the payg setting here.
Are you then hard rebooting after saving APN?
