francsitdayalo
Oct 10, 2021Follower
Netgear Nighthawk M2 - MR2100 - Wifi has red circle X and battery not charging
Hi, I recently got the Netgear Nighthawk M2 and I havent used it in a month, when i tried opening it it doesnt emit a wifi signal and the wifi icon has a red x on it. i tried turning ssid on and off ...
JohnPeng
Nov 23, 2021NETGEAR Expert
Can you do a factory reset to see whether the issue goes away? Did you buy it brand new?
Thanks
- kazuarNov 26, 2021Aspirant
I have exactly the same problem. I got a brand new device and the wifi is not working from the beginning. Cable connection works fine. Any idea? Seems like this device is faulty.
