sweete
Nov 05, 2019Guide
netgear nighthawk M2 and port forwarding
A client recently purchased this modem and i cant believe it doesnt support port forwarding. i read that a new firmware had come out but i cant find it. i also read that that firmware was buggy so ma...
michaelkenward
Nov 06, 2019Guru - Experienced User
It does according to the manual.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
- sweeteNov 06, 2019Guide
thank you for your answer, but i am sorry, it does not! if you read other community posts about the same model they are also quite disgruntled that it does not. i have a M1 and it DOES, so i am going to swap it over with my clients. it is ridiculous that an older one supports and and newer one doesnt. this is only an interim solution until their nbn is connected and i can put a good grade class firewall in along with a modem.
