graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
gavrook
Mar 26, 2020Guide
What happened to this supposed new firmware?
JohnPeng
Mar 26, 2020NETGEAR Expert
The release has been published two weeks ago. Please do a manual FW update check.
Thanks
- gavrookMar 26, 2020GuideHi John, thanks but I have done dozens of firmware upgrade checks both on the touchscreen and via the web interface as well as a factory reset and nothing is being found
- JohnPengMar 26, 2020NETGEAR Expert
Could you please check what is the FW version and PRI version on your device?
We release the FW upgrade as mandatory. So you device may have pick up the update automatically without your awareness.
The last FW: 10.17.01.00; PRI version: 04.02
Thanks
- gavrookMar 26, 2020GuideHi, my device is still on firmware NTGX24_10.13.05.00 with PRI Version 02.10
- em1Nov 05, 2021Aspirant
FSN: 5J1192N801BAO
