graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
gavrook
Mar 26, 2020Guide
Hi John, thanks but I have done dozens of firmware upgrade checks both on the touchscreen and via the web interface as well as a factory reset and nothing is being found
JohnPeng
Mar 26, 2020NETGEAR Expert
Could you please check what is the FW version and PRI version on your device?
We release the FW upgrade as mandatory. So you device may have pick up the update automatically without your awareness.
The last FW: 10.17.01.00; PRI version: 04.02
Thanks
- gavrookMar 26, 2020GuideHi, my device is still on firmware NTGX24_10.13.05.00 with PRI Version 02.10
- JohnPengMar 26, 2020NETGEAR Expert
gavrook wrote:
Hi, my device is still on firmware NTGX24_10.13.05.00 with PRI Version 02.10Seems like you are using a Telstra MR2100. We have submit the new release to Telstra last week for approval. The upgrade will be posted in next couple of weeks if Telstra can finish the test on time.
Thanks
John
- GerardOzMay 11, 2020Guide
JohnPeng wrote:
Thanks
John
JohnPeng
Hi John,I am about to buy an M2 off Telstra Australia, and will need to use Nertgear orbi or a Mesh wifi set up of some sort to extend the wifi range. All the forums are saying that the IP Passthrough is disabled in Telstra supplied M2's in the software. Mention is made of this changing in an upocoming firmware update, Is this true have they switched that function back on again ? It is impossible to contact Telstra technical due to Covid 19 now.
Or I can get an as new M1 secondhand and apparently I.P. Passthrough could be done on this model with telstra but then people reported on forums that they did one update and lost the function after that rendering the unit useless for their purpose. But that it was meant to be re-activated in a later update. The M1 will be fine for my requirements but I'm having a real hard time of finding out the facts on this.
Do you know about this?
Cheers.
Gerard.
- wombatusMar 30, 2020Initiate
Hi all,
my mr2100 is stuck on NTGX24_10.16.03.00 with PRI 03.02 - I have reset it to defaults but the firmware update check never finishes.
Any ideas?
Best
- hh74Mar 31, 2020Aspirant
Same issue here - Firmware update check never finishs.
Firmware NTGX24_10.16.03.00
Is there any other option to install most recent firmware?
