graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
mcuadrado
Apr 21, 2020Guide
Hi, could you provide your device IMEI number please, reply privatelly.
Regards!
W1lliam wrote:100EUS is a retail model, why firmware upgrade can't be done as MR1100-100EUS, customer can do their own decision to proceed the upgrade instead of relying on OTA and cost you data charge from carrier?
JohnPeng
Apr 22, 2020NETGEAR Expert
It has been confirmed by one of EE UK customers that after he switch to another network, his device can be upgraded successfully.
We are working with EE UK to resolve the issue.
Thanks
- ianstephensApr 30, 2020Tutor
Confirmed issue on EE UK. Have switched to Vodafone SIM and performed the update successfully.
Issue may be IPv6/IPv4 settings - maybe the carriers 6to4 could be the issue if Netgear only deliver over IPv4.
- color_8Apr 30, 2020Aspirant
i have a ipv4 static ip on my a1 sim card. no firewall nothing. the update don't work with this sim card...
- Luki_HofiApr 30, 2020Aspirantmaybe the european wide upc connection issues have something to do with that
- JohnPengMay 01, 2020NETGEAR Expert
Thanks for reporting this upgrade issue. We are investigating now and will let you know whether we can do anyting on the devices to help resolving the issue.
Regards
- KrzysztofKarolMay 09, 2020Aspirant
If that helps:
Country: Switzerland
Firmware Check
does not work with digitec (Sunrise)
works with SaltFirmware Version: NTGX24_10.17.01.00
- JohnPengMay 11, 2020NETGEAR Expert
Thanks. The information is helpful.
Regards
KrzysztofKarol wrote:
If that helps:
Firmware Check
