graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
GerardOz
May 11, 2020Guide
Its a total joke on Netgears behalf then if theres people all with the same updates but got different functions. Does anyone know of a good comparable modem or router that'll take a sim and do the I.P. passthrough without all these problems? Ideally with remote access like nighthawk has. i'm looking for something stable too that doesn't need rebooting every day as its for my alarm and security on my house when I'm away for long spells. NBN in my area is a joke so have to be on the 4G.
W1lliam
May 11, 2020Virtuoso
I am using unlocked MR2100-1TLAUS, with non-Australian carrier, maybe that is the major different?
- GerardOzMay 11, 2020Guide
W1lliam How do you update yours thenas its an AUS model, it will have been telstra originally and your in a different country as your on a Non-australian carrier?
- W1lliamMay 11, 2020Virtuoso
not sure why, but when I clicked check firmware upgrade, it works when I was with carrier for non-Australian
W1lliam Ohh ok so I get it now, whatever carrier you are on now with, its that carriers settings your getting from their Firmware which are different to Telstra here in Aus. So therefore you get the I.P. passthrough. The carrier your with must be selling the M2 also then, but you just have the Aus version. It must be unlocked too is it to work on that carrier?
