graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
W1lliam
May 11, 2020Virtuoso
I am using unlocked MR2100-1TLAUS, with non-Australian carrier, maybe that is the major different?
GerardOz
May 11, 2020Guide
W1lliam How do you update yours thenas its an AUS model, it will have been telstra originally and your in a different country as your on a Non-australian carrier?
- W1lliamMay 11, 2020Virtuoso
not sure why, but when I clicked check firmware upgrade, it works when I was with carrier for non-Australian
- GerardOzMay 11, 2020Guide
W1lliam Ohh ok so I get it now, whatever carrier you are on now with, its that carriers settings your getting from their Firmware which are different to Telstra here in Aus. So therefore you get the I.P. passthrough. The carrier your with must be selling the M2 also then, but you just have the Aus version. It must be unlocked too is it to work on that carrier?
GerardOz wrote:W1lliam Ohh ok so I get it now, whatever carrier you are on now with, its that carriers settings your getting from their Firmware which are different to Telstra here in Aus. So therefore you get the I.P. passthrough. The carrier your with must be selling the M2 also then, but you just have the Aus version. It must be unlocked too is it to work on that carrier?
OTA server should be still hosted by Telstra, even if the unit is with the SIM from other carrier. It might be caused by lock/unlock difference for this IP Passthrough function disabled.
