graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
Nicolas_Kleine
Aug 13, 2021Aspirant
Same here:
Model: MR2100
FW-Version: NTGX24_10.17.01.00
PRI 04.02
GUI Version: MR2100-100EUS_04.02.144.00
JohnPeng
Aug 13, 2021NETGEAR Expert
For M2 Upgrade issue, please try connecting via WiFi or Ethernet offline first. Then do the upgrade check.
The latest M2 EUS FW is 10.17.08.00 and PRI 05.04
Thanks
John
- HLiSep 29, 2021Aspirant
My device is unable to set the correct "Time and Date"
example: Data offloading since 6/1/20 6:28 AM
My Firmware ist NTGX24_10.17.08.00
Is the any support on this Issue? Or is it better to send the Unit back to Amazon?
- JohnPengDec 19, 2021NETGEAR Expert
Your device is already on the latest FW. Please do a factory reset and see whether the date and time issue can be resolved,
Thanks
- IYGEALJan 01, 2022Aspirant
My Router Model is MR2100-1TLAUS_04.02.181.00, Firmware Version is NTGX24_10.17.10.00 with Build Date of 2020/08/21.
My problem is that the router keeps saying "Your Wi-Fi Network is disabled". For this reason, I cannot connect any device via wifi. I tried to see if the FW can be updated but it sticks on "checking" each time I try to update from the router itself. Today I connected my pc via USB-C and logged in, on the web interface, the checking still yields to nothing. I used my PC hotspot (which is now powered by my router via USB-C) to connect the mobile app succesfully but the FW still cannot be updated.
Bear in mind that each time the wifi disabled error pops up on the router, there is an option to enable it which does exactly nothing. The error also pops up on both web and app interfaces but with no option to do anything.
All my settings are correct but my devices cannot wirelessly connect to my router because the wifi is apparently permanently disabled. I wish this can be fixed but I found nothing on this whole thread that can help.
- AutobahnAmericaDec 18, 2021Aspirant
AutobahnAmerica wrote:
JohnPeng,
Have M2100-100EUS. What's the most current FW as of 18 Dec 2021?
Thanks!The latest current FW for MR2100-100EUS is NTGX24_10.17.08.00, PRI05.04.
Thanks
- AutobahnAmericaJan 01, 2022AspirantThanks for the quick reply. Sorry mine wasn't .
