graemedurie
Mar 09, 2020Follower
Netgear Nighthawk M2 Firmware Download
Does anyone have the latest firmware for this device, Netgear support will not provide it.
IYGEAL
Jan 01, 2022Aspirant
IYGEAL
The above is the web interface where I was trying to make changes. The settings is stuck and that option where the arrow points. If I attempt changing it, it never applies. It will keep saying applying till forever. Sometimes it quickly says "applied" but goes back to this option with the arrow. No other option applies.
I suppose this is something a firmware update may solf but the fw update checking, like I wrote earlier, is not working. I have been using this device for a year or so. This happened suddenly. I recall seeing fw update prompt on the router some weeks ago when it was still working.
- IYGEALJan 01, 2022Aspirant
I forgot to add that I have made several factory resets - including through the pin at the battery side - all of which were successful but still changed nothing. WiFi name and password on the device's homescreen show Disabled respectively. Also, I did NOT select USB Tether only (Disable WiFi) in the setting.
It's quite frustrating.
