MichaelDam
May 19, 2022Follower
Netgear Nighthawk M2: Update manuelly via USB possible?
Hello Is it possible to update the firmware via USB manuelly? Thanks in advance. Kind regards Michael
michaelkenward
May 19, 2022Guru - Experienced User
No. But you can do this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Why do you want to use USB?
