Beetroot_48
May 19, 2019Aspirant
Netgear Nighthawk M2 USB Media Storage
Hi everyone,
Just wondering if anyone else has found a work around or a contradiction in the user manual for the Nighthawk MR2100 for USB multimedia use. I was hoping to be able to use mine to ...
- Jun 30, 2019
Hi 3lad3 ,
It is fine to keep the battery plugged in whilst using the wall adapter. We recommend to remove battery if it is prolonged use. In your case where you need MyMedia access I would suggest removing the battery periodically for a few hours just to cool it down(i.e fortnightly or quartely). The firmware has smarts to trickle charge when battery is 100% charged but if the device or battery is constantly running hot(due to heavy usage) then it will never get a chance to charge. This is why I suggest removing the battery periodically.
Arodi
Community Team
3lad3
Jun 30, 2019Aspirant
Thanks Bryant. I've updated to the latest, and it's still the same.
Arodi, thanks for the reply to the thread. Given that media access is a feature I'd need constant access to, then we need to keep the battery in and plugged in to power 100% of the time then too. I'd then assume that the battery is fine with this setup then given that's our only option?
ArodiD
Jun 30, 2019NETGEAR Expert
Hi 3lad3 ,
Arodi
Community Team
