JimmyMars's avatar
JimmyMars
Follower
Apr 15, 2021
Netgear Nighthawk M2 WiFi enable schedule
I would like to enable the wireless schedule.
1. I went to the configuration page of my router: routerlogin.net
2. Logged in
3. Setting -> Security -> Schedule
4. Created a schedule: 5 a.m. to 9 p.m.
5. Clicked the enable tickbox and select apply from the bottom tab
The instructions here were outdated: https://kb.netgear.com/24102/How-do-I-set-up-the-wireless-schedule-on-my-Nighthawk-router#
But now after updating, it doesn't work as expected. The WiFi is not shutdown at 9 p.m..
I cannot find the option to change the timezone in this configuration page.
Shall I revert to an older firmware?
Current latest firmware version: NTGX24_10.17.08.00
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi JimmyMars,
    Welcome to NETGEAR Community!
    Have you tried factory resetting the device?
    The KB article that you posted is not applicable for Mobile routers.
    For Nighthawk Mobile router, you can setup a schedule for Internet access. Here's a reference:
    https://www.downloads.netgear.com/files/GDC/MR2100/MR2100_UM_EN.pdf [page 48]
    Blanca
    Community Team
