F911E307-D708-4
Oct 02, 2021Aspirant
Netgear Nighthawk M5 Admin UI only local access
Hi, I've just bought a Netgear Nighthawk M5 from Telstra to use with a USG3 and found that the Admin UI only works if I connect to the M5's WiFi or its ethernet port. What I want to do is con...
cyberfox
Jan 13, 2022Tutor
I have the same challenge. Not able to access admin UI from any external IP.
