Erich_Snijder
Jun 14, 2022Aspirant
NETGEAR Nighthawk M5 Mobile Router band and channels.
Dear, I am looking at buying the Neatgear Nighthawk MR5200. Now first I want to know on which channels / bandwidth the MR5200 can operate in 5GHz mode. The intention is to connect my Nikon Z9 to i...
michaelkenward
Jun 14, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. In your case, your are asking about the M5 Mobile Router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Erich_Snijder
Thanks for the response.
I've been looking on the support page but can't find the info i need.
I didn't buy the Nighthawk because first i want to now what channels are use under 5GHz.
At this moment i got an Huawei and that one uses only channel 100.
The Nikon Z9 uses an range from 36 to 64.
So buying is first to now i can work with 5GHz.
Thanks anyway.
- michaelkenwardJun 14, 2022Guru - Experienced User
I have no idea what the Nikon Z9 is, but if it works with wifi, then Netgear's routers are going to support bands that are in common use.
