Erich_Snijder
Jun 14, 2022Aspirant
NETGEAR Nighthawk M5 Mobile Router band and channels.
Dear, I am looking at buying the Neatgear Nighthawk MR5200. Now first I want to know on which channels / bandwidth the MR5200 can operate in 5GHz mode. The intention is to connect my Nikon Z9 to i...
Erich_Snijder
Thanks for the response.
I've been looking on the support page but can't find the info i need.
I didn't buy the Nighthawk because first i want to now what channels are use under 5GHz.
At this moment i got an Huawei and that one uses only channel 100.
The Nikon Z9 uses an range from 36 to 64.
So buying is first to now i can work with 5GHz.
Thanks anyway.
michaelkenward
Jun 14, 2022Guru - Experienced User
I have no idea what the Nikon Z9 is, but if it works with wifi, then Netgear's routers are going to support bands that are in common use.
