Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
idck_de
Sep 28, 2021Tutor
Hi. For MR5200 owners
All of you guys encountered this mirror is using a commercial add-on plan on pSim that you put in your MR5200?
If does, I guess it perhaps because of carriers end occupying switch IP pool or duing devices Mac address check.
I do own one of those MR5200s with multiple pSim card for variety of carriers from different brand.
For occasionally, I also put in IoT pSim in my MR5200 unit. Because one of special perks for some IoT card is server end rarely switch IP/ Mac address check. Stable resolve be solid at my part of usage.
- salwooNov 02, 2021Guide
idck_de wrote:Hi. For MR5200 owners
I changed my sim card plan to a data only sim card 2 weeks ago, the internet drop just happen 1 time.
I just wonder is there any problem after recovering the internet connection. I double checked when the internet connection recover, the admin page for MR5200 can't be access, I checked at the MR5200 everything seems ok, there have internet traffic itself. Seems the MR5200 in an isolate mode, no device can get a connection. And need to reboot to recover everything.
I agree with your suggestion a stable data plan will help, but seems the firmware have some problem when the internet drop and recover.
Fred
- idck_deDec 04, 2021Tutor
Hi. Great progress that hear from you.
So to work on stabilize and minimize disturb from cellular what you have done is resign plan to data only. Which is worked in your case.
You described another problem that under that MR5200 recoving from ISP connection. The admin page is unaccessible. And here is what i through it could be undone and misunderstood. Furthermore wish more discover will post in here and helps both teams and coummnities to drive it furthers.
It could be resolved by timely. If you closer look it usually takes 10+- mins for MR5200 to reestablish signed address pool to boardcast them to end devices. There's any reason at all to harsh in is the reboot target system by force it to recalibrate all the essential stuffs that matters to end devices connections. Like so your end devices at that time has some sign of warmming that the Network MR5200 provided at the time don't have internet. Therefore it might not interchangeable during MR5200 not in a state of renew or establishing refreshed assignments.
I saw you risen up another issues that releted to MR5200 system timer as well. The MR5200 can be boardcast this functions to end devices by amount of time, And to be sure that MR5200 has granted timely data from servce end. It's linked like chain reactions you see. First is time data giver assigned by Netgear software engineers or co-contractors software builders. Secondly, it's amount of Round trip time cost by transfer it from time giver to MR5200. If you encountering unusual time that wrongly established to end devices you need to work on Sim card provider to ask them a ticket to their server management to check out if any ports that signed to time services is jammed or shuttered. which's most likely in my humbled opinions.
If cellular feedback business as usual. Lets switches to any other similar devices like MR5200 ( I do use Verzion MR2100 from ise as back up). to check out time assignments and how it works out on your end devices.
Other than that, Change your time giver see if works. Most of end devices can have dedicated timing services. If they allow users to change them.
