Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
JohnPeng
Nov 02, 2021NETGEAR Expert
Thanks for everyone's feedback. Our team is looking into the issue and will make improvements on the connection stabiliy between WAN port and router client.
Regards
rylos
Nov 23, 2021Star
When is the solution coming? I've the same issue using mr5200 with a Belkin 3200 router; after 2-3 dayes wan is not visible from outside. Rebooting the mr5200 fix the issue.
