Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
JohnPeng
Nov 02, 2021NETGEAR Expert
Thanks for everyone's feedback. Our team is looking into the issue and will make improvements on the connection stabiliy between WAN port and router client.
Regards
Rob_t_g
Dec 01, 2021Aspirant
Hi Team,
we're running into the same issue with the IP passthough failing every few days.
ISP is Telstra - Australia.
I've tested with several Meraki models and Fortigate models. and can supply some debugs if it helps.
Has the root cause been identified as yet?
any idea when an updated firmware will be available?
thanks
