Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
JohnPeng
Aug 08, 2021NETGEAR Expert
Thank you for everyone's report. we will investigate and provide the feedback soon.
Regards
John
NoV1m
Dec 19, 2021Tutor
Seems like the problem was there in august, it’s December. Do you have any idea of when will it be solved please? Should I purchase another device? Or get mine replaced?
