Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
NoV1m
Dec 27, 2021Tutor
Hello there
Seems like there isn’t any solution yet to this problem. Is it a problem on all M5? Should I get a replacement? Does other 5G netgear routers have this issue? Would love to have more informations about all this.
Thank you
Thank you
rylos
Jan 04, 2022Star
Hey, is a solution to this problem so hard? MR1100 is working fine for me and MR5200 is loosing wan ip address over the lan port after 2-3 days max. This device is a costly paperweight for now...
