Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
salwoo
Apr 17, 2022Guide
Seems no update from Netgear team (even the progress update), I have switched to Linksys fgw3000. Sometimes the WAN will drop, but it will recover within 30 sec.
RonGonz
May 03, 2022Star
JohnPenghas Netgear made any progress, are there any updates on this issue? When can we expect a firmware update with some more reliable operation for Netgear's flagship Mobile Router?
- pistachioMay 22, 2022Tutor
Same here, random deconnection of the WAN port. IP passthrough worse than router.
(setup : Mr5200 is hooked to a sinology 2600 on its WAN part, and my DSL router on the secondary LAN for the Synology for fallback ... and it fallbacks a lot)
Having a fixed DHCP may have helped here in my case to force the DHCP of the Synology ... but well IP passthrough should work....
For now very disappointed in the product stability, especially for the price (750 euros here in France), but not really any other solution.
Trying a few days experiment by connecting to the sinology router through USB .... unfortunately the sinology USB seems limited to around 80Mbps ... but better than nothing if it stays on (The MR5200 can get me between 200 and 300Mbps where I live) vs the daily or more than daily disconnection du to loosing the ethernet from the MR5200.
- Blanca_OMay 22, 2022NETGEAR Employee Retired
Hi pistachio,
I have sent you a message. Please check your inbox.
Blanca
Community Team
