Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
deep83
Jul 31, 2022Initiate
I'm having a similar issue.
IP Passthrough on.
DHCP left on.
Ethernet standby off.
Connected to a TP-Link ER605 via WAN.
Goes offline every few hours and reports IP address as 0.0.0.0.
In response to a previous post, I don't think purchasing a smart plug, to power cycle the device, or a subscription to Netgears cloud management are reasonable - this function should work.
Can you give us a timeline for a fix? Or should I return these for a refund (not working as expected / faulty)?
jpparkerjr
Jul 31, 2022Aspirant
I used my m1 in pass through with no issues but lightning fixed it not in a good way like I said I have been able to establish decent connections by turning off pass through and using an extender because it has got to have the worst range of any wireless device I have ever seen. If you are not in the same room with it it drops out
- pistachioAug 29, 2022Tutor
Amazing that there is no progress on this. Tech support has conversation with me foe months’ made some tests with them … but still not working at all…my m5 can’t be used nor returned. Perhaps I should get a M2, but not sure it is better
- jpparkerjrAug 30, 2022AspirantI’m using it in not pass through I’m using it as hot spot with an extender on att it still has issues it will show speed tests that are great and try and stream and it pauses it could be att I have old unlimited hot spot plan but there’s no way there’s network congestion I live right by tower and there’s not many people on att in a 5 mile radius I’m looking for a m1 it worked good until lightning got it just hate to pay 250 for such an old device if I can find one at a decent price just gone sell m5 on eBay
